AURIX™ Forum Discussions
hmkum
10 replies posted 5 replies posted 5 questions asked
do you have any Flash/EEPROM endurance calculator for Aurix 2G TC367? If yes, could please share it?
Renesas has a excel sheet called EEPROM Emulation Endurance Calculation Sheet and NXP has an application for that.
https://renesasrulz.com/rh850/f/rh850-forum/17468/rh850-f1k-flash-endurance-calculator
https://community.nxp.com/t5/S32K/Flex-Memory-Endurance-calculator/m-p/1224825
Thanks in advance,
Hakan
NeMa_4793301
Level 6
Level 6
The MCAL FEE/FLS driver comes with a calculator (TC3xx_SW_MCAL_FEE_Cycle_Calculator.xlsx).
NeMa_4793301
Level 6
Level 6
hmkum
Thank you so much. That's really helpful.
hmkum
The calculator specifally says "This calculator is meant only for the users of Infineon's TC3xx MCAL FEE driver that operates on DF0 in single ended sensing mode.". Is it OK to use for DF1? If there is an another document for DF1, I couldn't find in HSM MCAL folder.
NeMa_4793301
Level 6
Level 6
The HSM's FEE/FLS in the HSM MEM package uses the same algorithm as the MCAL FEE/FLS, minus the quasi-static pool. You can use the calculator for DF1 also, as long as you adjust the size (128K).
