Mar 21, 2020
07:10 PM
Mar 21, 2020
07:10 PM
Hello Support,
For Aurix 2G, in the MCM_CAN module when internal loopback mode is selected via NPCRi (i=0-3).LBM=1 for a CAN Node, then RXSEL field of NPCRi (i=0-3) register is ignored or it has to set to a Port Pit?
Best Regards
Best Regards
08:07 AM
Mar 23, 2020
08:07 AM
Internal Loop Back Mode disconnects RXD:
Internal Loop Back Mode is entered by programming bits TESTi (i=0-3).LBCK and CCCRi (i=0-3).MON to one. This
mode can be used for a “Hot Selftest”, meaning the M_CAN can be tested without affecting a running CAN system
connected to the pins TXD and RXD. In this mode pin RXD is disconnected from the M_CAN and pin TXD is held
recessive.
Mar 24, 2020
04:50 AM
Mar 24, 2020
04:50 AM
Hello Support,
I am asking about the following section from User Manual Part 2 Revision 1.4 :
40.3.1.4.1 Module internal Loop-Back Mode
Figure 587 Module Internal Loop-Back Mode
My question was not for the section "40.3.2.1.9 Test Modes".
Please let me know for the section 40.3.1.4.1 whether RXSEL value is important or not.
Best Regards
Best Regards
Mar 24, 2020
06:36 AM
Mar 24, 2020
06:36 AM
Have a look at Figure 588 Module Loop-Back Mode Out. RXSEL is important for Normal operation and Loop Back Mode Out. RXSEL is not used for Internal Loop Back mode.
