Hi, I'm studying about uart communication and try to make example of echo program.
I'm aurix test board(TC3x7 TH V2.01)
I made attached uart example, and i successed to send message from MCU to PC when i put reset button and i check it via Hyperterminal interface.
so i want to made echo program. this program repeat the character i input hyperterminal interface.
To check receiving status, i set LED when receiving interrupt happen.
but with attached program, i can't type any character in hyperterminal interface.
what should i check or made modification on sourcecode? please help me.
thank you.
- uart receiving
1. Please refer to slide 10 of ASCLIN_Shell_UART_1_KIT_TC397_TFT for illustration of "echo" feature.
2. You can refer to the attached screenshot for implementation of Echo function. This uses IfxStdIf_DPipe_print() function in Ifx_Shell.c file. You can refer to this and adapt at your end.
Aiswarya.
Can you check the Aurix Development Studio example ASCLIN_Shell_UART_1_KIT_TC397_TFT
Best Regards.
hello. I chekced the example you suggested. but the example use 'Shell' Interface.
is there another example or sample code that implement echo function?
thank you.
Aiswarya.
