AURIX™ Forum Discussions
User14162
In Application manual states that After the first connection of USB to a PC the needed driver will be installed automatically.
During this there will be created a new COM port on PC. This COM port can be used to communicate with the board via ASC0 of the device.
NOTE: Before connecting the board to the PC, make sure that the actual DAS software
is installed on the PC.
But in my case it does not creat a new port on PC.
Does anyone can guide me why is it so and how to establish the TC2X4 kit's Serial Connection to PC?
Usman2900.attach
v2900.attach2900.attach
User13290
First solution authored
Hi Usman,
Usman
Could it be that you're facing the same issue as listed in this thread?
Henk-Piet Glas
Principal Technical Specialist
p.s. It looks as if you got your board running again. Did the suggestions in this thread help or was it something else you did?
