AURIX™ Forum Discussions
Mmmmmm
First like given 10 sign-ins 10 questions asked
at tc39 the smu core alive alarm flag isn't raised although the smu alive test command is received  is received successfully
Nambi
First like given 25 likes received 50 solutions authored
I tried the below sequence when SMU_DBG.SSM = 0 //START state.
Ifx_SMU_CMD cmd = SMU_CMD;
/* Send Software error command */
cmd.B.CMD = 0x7; cmd.B.ARG = 0x5;
SMU_CMD.U = cmd.U;
while((SMU_STS.B.CMD!=7) || (SMU_STS.B.RES!=0)){}
I could see that PMS_AG21_STDBY.SF16 gets set.
Best Regards.
Aiswarya
100 sign-ins 10 solutions authored 25 replies posted
Could you please share the code snippet and how are you confirming that the flag is not raised?
Could you also share the corresponding register values?
Aiswarya.
After IfxSmu_startAlivetest() DONE PMS_AG21_STDBY (SF16) is still zero
help me
Nambi
You can refer to the thread https://community.infineon.com/t5/AURIX/SMU-Alive-Alarm-test/td-p/317612
Best Regards.
Mmmmmm
He didn't get the solution and i have the same problem when i call Start AliveTest(); the alarm didn't set as i shown in photo
Mmmmmm
i can't find solution until now
Nambi
You can check the value of SMU_STS register after calling IfxSmu_startAlivetest(), especially SMU_STS.RES?
Best Regards.
Mmmmmm
command is received but alarm flag doesn't raised  Screenshot 2022-12-26 105044.png
Mmmmmm
any help ?
Mmmmmm
i don't spam but no one help me
Nambi
SMU_CMD.U = cmd.U;
Best Regards.
Mmmmmm
Unfortunately the same problem,
is the problem may be because I use trace32 as a simulator, not debugger ?
Nambi
The register SMU_DBG.SSM is not seen here in your post.
i) You can confirm if SMU_DBG.SSM is 0.
ii) You can test on an actual device to eliminate the simulation factor.
Best Regards.
Mmmmmm
Yes SMU_DBG.SSM is Zero , smu is in start state .
