After I transferred the PF0 program to SRAM to run, then executed [Erase Logical Sector Range] in sequence.
It work well, HF_ERRSR did not report an error, and HF_OPERATION also passed, no busy.
But when I check memory dump by TASKING, it is true that almost all the data is displayed as "0", but there are a few bits that are "1".
I thought it was due to bad memory or unstable current and voltage. So I repeated the test several times and changed the Triboard, but the result remained the same, it could not be erased to "0" in several fixed address.
I took a screenshot of part of it.
[Erase Logical Sector Range] can be that all PF fields become 0, is my understanding wrong?
Thank you for watching.
You cannot directly read PFlash after an "Erase" operation. As you stated you have checked HF_ERRSR
and HF_OPERATION for errors and there were none. If you want to check the erased state of PFlash then you need to use the one of the following commands:
Thank you for your answer, I have learned more about AURIX's ECC and flash command.
