williamdong
10 sign-ins 5 sign-ins First like given
I  had locked the debug interface(JTAG) by config UCB_DBG.  now I use a wrong password to access the device through JTAG debug interface,  Does the device have some event to alert you that is an illegal access?
I didn't get any information from the user's manual  tc23x_tc22x_um_v1.1.pdf , I hope to get some answers from you.
thanks
william
Di_W
HSM part please not post here, but password can unlock Debug Interface again.
Di_W
UCB_DBG is used for the password protection for the debug interface. PROCONDBG is a register to show if OCDS enabled and if UCB_DBG debug interface lock is configured.
Details is in Section 4.1.6.4 - sub section Debug System handling of tc29xB_um_v1.3.pdf.
Thank you for your prompt reply,  I have another question need your help. when i disable debug interface by software. the debug interface had been locked.But Lauterbach could not connect through the password set, showing "debug secured". What should I do to get my device back.
in another device, I just erased the sector where the UCB BUG was located. As a result I can't connect to it. What should I do in this situation, thank you very much
best
william
Di_W
Hi william, if you erased UCB, the chip will be bricked. If you lock the debug interface, then cannot debug, but password can unlock it.
My device is TC234L , If I want to implement the lock interface by modifying the UCB_DBG, What should I do?
Di_W
