ismMAT
Level 4
Level 4
Distributor - Macnica (Japan)
25 sign-ins 10 replies posted First solution authored
ifx_oe_pack_structure.h is missing in oneeye_lib(in C:\Infineon\Tools\OneEye\2.54.2.202212141707\bin\firmware\aurix\oneeye_lib), which is declared include in ifx_oe_al.h. This will result in a compilation error.
Of course iLLD is already implemented, but iLLD doesn't have it either. where can i get this file?
Prudhvi_E
250 replies posted 100 solutions authored 25 likes received
Could you please try with the version "2.52.0.202210191051" and let us know if it works for you?
In the meantime, we'll check the issue internally and provide an update.
Prudhvi.
Prudhvi_E
Prudhvi.
ismMAT
Level 4
Level 4
I tried with version "2.52.0.202210191051" and it worked. Thank you very much.
I hope the next version will fix it as well.
