ifx_oe_pack_structure.h is missing in oneeye_lib(in C:\Infineon\Tools\OneEye\2.54.2.202212141707\bin\firmware\aurix\oneeye_lib), which is declared include in ifx_oe_al.h. This will result in a compilation error.
Of course iLLD is already implemented, but iLLD doesn't have it either. where can i get this file?
Could you please try with the version "2.52.0.202210191051" and let us know if it works for you?
In the meantime, we'll check the issue internally and provide an update.
Prudhvi.
Prudhvi.
I tried with version "2.52.0.202210191051" and it worked. Thank you very much.
I hope the next version will fix it as well.
