Sep 18, 2019
03:20 AM
Sep 18, 2019
03:20 AM
I write asm code with HighTech, I select tricore-gcc as my asm-tool, and I found some problems
I found the rule of tricore-gcc for asm is different from the asm-tool in the "TriCore DSP Optimization Guide".
for example, some codes always compiled NG:
mulr.h %d3, %d4, %d5 ll, 1
maddsur.h %d4,%d3,%d4,%d5 uu, 1
the compiler always told me:
../src/cycleTest.S:18: error: Opcode/operand mismatch: mulr.h %d3,%d4,%d5 ll,1
../src/cycleTest.S:20: error: maddsur.h %d4,%d3,%d4,%d5 uu,1: Too many operands
I don't know how change my code.
Can I get the asm language guide for TriCore-gcc? how and where?
Another problem, I think TriCore can provide intrinsic(C language) for the DSP instruction.
I don't know how to obtain these instrinsic's guide, Is there anyone can tell me?
Sep 18, 2019
04:46 AM
Sep 18, 2019
04:46 AM
Hi Shaquille,
Concerning your first question, the ll suffix needs to be appended to the register. So rather than using:
You'll have to use this instead:
mulr.h %d3,%d4,%d5ll,1
For your 2nd question I think you're referring DSP lib source code, developed by Infineon. This is probably available via the MyICP channel. If you've not signed up to it yet then you can use this link to do so.
Henk-Piet Glas
Principal Technical Specialist
Embedded Software
Sep 18, 2019
05:15 AM
Sep 18, 2019
05:15 AM
Dear Henk-Piet Glas:
Thanks for your promption for my 1st question.
2nd, I don't mean "DSP lib", I mean "intrinsic function", for example:
c code __mulr(....) -> asm code mulr
c code __madd(...) -> asm code madd
and so on....
I cannot find this instrinsics' guide in myICP.
and so on....
Sep 18, 2019
07:22 AM
Sep 18, 2019
07:22 AM
Hi Shaquille,
The AURIX tools support a number of builtin functions. These are listed in chapters 7.1 and 7.2 of your user manual. In addition we support a number of intrinsics as well. These can be added to your source code using:
#include
int main(void) {
/* whatever */
return 0;
Physically this file can be found in tricore/include/machine relative to the root of your installation.
The specific intrinsics that you are referring to, do not exist in our tools. You either have to create them yourself using either C or inline assembly (see chapter 8 of our user manual) or you need to discuss this with your Infineon representative.
Henk-Piet Glas
Embedded Software
Sep 18, 2019
09:05 AM
Sep 18, 2019
09:05 AM
thanks for your help
Sep 18, 2019
10:52 AM
Sep 18, 2019
10:52 AM
No problem. Happy to help.
Henk-Piet Glas
Embedded Software
