On page 11 of AURIX™ TC3xx Using the SWAP mechanism for Software Updates Over The Air (SOTA).pdf (AP32404 v1.2), it is mentioned to modify the linker file and use this adapted file to compile the image suitable for A banks.
What I want to ask is, What I want to ask is what kind of linker file needed to compile the image for B banks (inactive area) ? What kind of linker file is needed for image compilation for subsequent A banks upgrades?
Aurix
You shall use the same as swap will interchange the physical memory maintaining the same execution address. You can check the same for your selected device in the app note.
