Galanoth
First reply posted First like received First question asked
I am using SAK-TC367DP-64F300S AA in my project and supplying that MCU with TLF35584QVVS1 (5V variant).
For the VDDP3 pins should I supply the pins with 3V3 externally or is there an internal LDO in MCU that provides the 3V3 supply for the VDDP3 pins?
Best regards.
Prudhvi_E
250 replies posted 100 solutions authored 25 likes received
I think you're supply mode is Single Supply as described in "Figure 133 EVR Switch mode topology (a) - 5 V single supply". The 3V3 can be internally generated from EVR33 LDO. Please refer to the section "12.2.2.1 Linear Regulator Mode (EVR33)" in the UM below:
https://www.infineon.com/dgdl/Infineon-AURIX_TC3xx_Part1-UserManual-v02_00-EN.pdf?fileId=5546d462712...
Prudhvi.
Prudhvi_E
Prudhvi.
