Is it possible to use AURIX Development Studio when connecting via a miniWiggler to a custom board with TC399XX256..... processor and using the HighTec tool chain? Or will AURIX only connect to the infineon demo boards that have the miniWiggler embedded in them?
If not, what is a reasonable solution to debugging using the miniWiggler?
- aurix
- miniwiggler
In my understanding, AURIX development studio bundles TASKING compiler(not Hightec) and those projects are prepared for certain evaluation boards(ex. Application board as know as TFT board, Lite Kit).
https://www.infineon.com/cms/en/product/promopages/aurix-development-studio/
For your combination(Hightec compiler, your custom board, external debugger), I think other environments would be appropriate. E.g. BIFACES from Infineon, 3rdParty’s environments.
Ikki
Hi @dpetzel ,
Thank you for your interest in Infineon's products and for the opportunity to serve you.
Please refer to the application note to set up the platform you want.
BR,
Jeremy
