Aug 31, 2022
01:27 PM
Aug 31, 2022
01:27 PM
We are using TC277TP-64. We have the 10 pin jtag connector on our PCB. I want to use AURIX development studio to do the following on the Tri Core chip (TC277TP-64):
• Pause, start and stop the CPU,
• Place break points,
• Read the registers
• Load the code into memory
I was trying to connect the DAP miniWiggler between our board (with Tri core on it) and host PCB.
1-Please let me know if miniWiggler is the correct interface.
2-If not, do you have another jtag debug hardware that complies with AURIX development studio.
3-If yes, how should I wire the 20 pin jtag port on the miniWiggler to 10 pin jtag. Is there a converter cable?
Behnam
Labels
08:23 PM
Aug 31, 2022
08:23 PM
Hi BehnamK,
https://www.infineon.com/cms/en/product/evaluation-boards/kit_aurix_tc277_trb/
If you want to use ADS debug with onboard miniWiggler, please refer to Triboard TC277 user manual which includes the sch. For external miniWiggler DAP port can be used.
dw
08:23 PM
Aug 31, 2022
08:23 PM
Hi BehnamK,
dw
