Hi.
I use a lot of AURIX MCU and HSM.
I currently need HSM Reset.
I couldn't find any explanation about HSM Reset in manuals.
How can I only reset HSM (Arm Cortex)?
< I already know HOST Reset, I need to reset only HSM>
Best Regards
Phillip
- aurix
Hi Lucas,
You could implement software reset for ARM Cortex M3 in HSM firmware and provide an interface to call from HOST through bridge.
https://www.infineon.com/dgdl/Infineon-AURIX_Hardware_Security_Module-Training-v01_01-EN.pdf?fileId=...
The HSM firmware is provided as API's through third party vendor, so probably it's not possible for you to do so, unless you are writing your own firmware for HSM.
https://www.infineon.com/cms/en/product/microcontroller/32-bit-tricore-microcontroller/aurix-securit...
Mathai
Hi Philip,
The information regarding HSM Reset comes under NDA. Let us know, if u have NDA with us, then we will provide access through Infineon myicp portal.
Mathai.
Hi Mathai,
I'm Lucas who is a team leader of Philip. We already have an NDA. the myicp account is heeguk.yang@fescaro.com.
Please guide us on how to reset only HSM separately with HOST(TriCore).
Lucas
Hi Lucas,
Mathai
