oneday
10 replies posted 10 questions asked 5 likes given
When using the code example to test SCU_WDT(in debug mode ), there are some question as follows:
when execute code line 61:   IfxScuWdt_serviceCpuWatchdog(IfxScuWdt_getCpuWatchdogPassword()); /* Service the CPU0WDT */,then use the "printf"  to print the REG "SCU_WDTCPU0SR" , the value of "SCU_WDTCPU0SR" shows as follows:
I think the WDTCPU0 is not really enabled,because the SCU_WDTCPU0SR.B.TIM = 0xFFFC and this value has never changed.
so,  how to  really enable  the  WDTCPU0 in debug mode?
Looking forward to your reply.
Di_W
Generally, FFFCh is counted up to FFFFh and then timeout, that means only 4 clocks to be expired, in this short window,  the user could do some operations.
Di_W
