AURIX™ Forum Discussions
User17486
Hi all,
Does anyone know how to configure RIF so that data comes from EVADC?
I use the chip TC397 B-step. I need to configure the collection of raw data from the FMCW radar module connected to the AURIX EVADC 4 analog lines.
I have found many examples of using RIF with external ADCs. But about the connection to the internal ADC information is quite small.
The documentation states that the sampling data will be available on the HDI bus (connected to the RIF) if the result is written to result register 15.
I tried setting up the configuration using iLLD, but nothing worked for me.
Maybe someone has some small examples of how to do this right?
Regards, Gennadiy
