Translation_Bot
In motor control, does PWM use a GTM module for PWM configuration and output PWM? What is the general configuration process.
For example, how to configure the PWM cycle, how to configure it in rising and falling mode, and how to configure it to cause interruptions (when the count is 0, how to set when the value is maximum).
I don't think the AURIX manual is easy to understand, so let me ask you how to get started.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/AURIX-PWM-%E9%85%8D%E7%BD%AE/td-p/656391
Translation_Bot
Hi @Clancy_Zhao
From your description, you can use GTM's TOM or ATOM to generate PWM. The GTM section in Aurix basically comes from the GTM IP provider BOSCH's user manual. At the same time, he also provides a user manual for PWM generation, which you can refer to.
At the same time, Infineon also provides a GTM routine for generating PWM, which makes it easier for...
BR,
Jeremy
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/AURIX-PWM-%E9%85%8D%E7%BD%AE/m-p/657577
FD_aurix
100 sign-ins 100 replies posted 5 solutions authored
you can start from the example (Aurix code Example ) on github. there are few exampled on PWM on basic functionality that might help you to start to understand how does it works
Translation_Bot
Hi @Clancy_Zhao
BR,
Jeremy
