Samad
10 replies posted 10 questions asked 50 sign-ins
Hi team,
We had designed custom AURIX TC397x board. We are flashing the custom board using AurixFlasher tool which is integrated in ADS itself. After 5-6 iterations of successful firmware updates, we could not able to flash the board.
AurixFlasher tool isErasing the firmware but could able to Program the flash memory(It is getting struck).
In Debug mode we could not able to flash the board, we are getting the following error.
 If we program the board using Memtool it is getting programmed successfully.
As it is not flashable with AurixFlasher Tool we could not able to use Debug perspective and debug it.
What is the reason behind this, are we missing anything. Please address this.
Samad.
orasec
First reply posted Welcome!
Which version of ADS are you using? After you program with memtool are you able to start working with ADS again? have you tried to flash the hex file using the standalone version of AURIX Flasher Software tool?
>>ADS Version: 1.9.4
>> No.
 Have you tried with standalone version of AURIX Flasher Software tool?
>> Yes, we observed the same behaviour.
Samad.
orasec
Please update ADS to the latest version and try to reproduce.
Anupama_A
50 solutions authored 10 likes received 250 sign-ins
Hi @orasec ,
Are you able to use the new ADS version properly or you're still facing some issues there?
Anupama.
Hi Anupama,
We tried flashing with latest ADS, but still facing same issue. With Memtool we can able program it but with ADS we couldn't.
Any debugging tips for it.
Samad.
Anupama_A
Hi @Samad ,
Could you please share the project you're facing this issue with so that we can try to reproduce the issue at our end?
Anupama.
