Oct 18, 2021
02:43 AM
Oct 18, 2021
02:43 AM
Dear all,
is it planned to support some Infineon TriBoards from AURIX Development Studio?
For example, right now there is no way to test anything with TC399, it would be useful use the TC399 TriBoard.
In the mantime, if there are some information or guideline to port examples made for Application Kits to a TriBoard, please let me know!
Thanks!
Thanks!
12:42 AM
Oct 19, 2021
12:42 AM
Hi Alessio,
You should be able to work with Triboard TC399 by creating a new project selecting the "TC39xXX_B-Step" device (or "TC39xXP_B-Step", depending on your hw) and a Custom board.
To port a code example, just create a new project for your board and copy-paste the code you need from the example and make sure the code is compatible 1:1 (you'll probably need to change some port pins..)
BR,
Matteo
BR,
Matteo
12:42 AM
Oct 19, 2021
12:42 AM
Hi Alessio,
BR,
Matteo
BR,
Matteo
Oct 19, 2021
08:05 AM
Oct 19, 2021
08:05 AM
TC35 ADAS support is also missing 😛
