AURIX™ Forum Discussions
User17121
Hello all.
we are using the E-Motor control application kit from Infineon with the TC234 AURIX. We were wondering if its possible to switch from the tasking compiler to another one within the same code provided by Infineon.
If its possible, what sort of modification to the code should be done. (we are beginners with the AURIX)
best regards
Ali Terro
User18504
Theoretically you should be able to run the same code by using the Hightec Free Licence only for Evaluation Purposes.
