Mar 03, 2021
12:50 AM
Mar 03, 2021
12:50 AM
I would like to start working with a TC397XE for a new project and I am looking for an evaluation board with this target where I can use AGBT.
KIT_A2G_TC397XE_TRB seems not available anymore on Infineon website and KIT_A2G_TC397_5V_TRB_S or KIT_A2G_TC397_5V_TRB seem not to have TC397XE mounted on them but other references.
Are there other references I have missed or do I have to switch to TC399XE evaluation kit ?
Thank you for your help.
Raktek
Raktek
01:02 AM
Mar 11, 2021
01:02 AM
Hi Ratek,
since Hitex is also offering the TC397XE device, there might be a board available.
As for my understanding the emulation devices are pin compatible with the non emulation variants (same package assumed).
Hence, you have on the Triboards also parts which can only be used with the emulation device. If you are able to change the Aurix
on the board with the emulation variant, you could have in the end the board you are looking for. All this assumes to have an extra microcontroller frame
soldered on the board where you can easily change the Aurix.
The offered KIT_A2G_TC397_5V_TRB_S Triboard has an optional Aurora connector (only with Emulation Device) on board, which indicates that you can also use the
board for an emulation device. Thus, the board might be available and the emulation device needs to be purchased on top, or maybe they can replace it directly. The board will
be then significantly more expensive.
For further information please contact Hitex directly.
Jens
Jens
Mar 16, 2021
12:44 AM
Mar 16, 2021
12:44 AM
Hi JenS,
Thanks for your answer. This is what I understood. I am checking internally if we have big constraint or not to switch to a KIT_A2G_TC399_5V_TRB_S where TC399XE is already mounted. This solution will be cheaper.
Otherwise, Hitex has some TC397XE device available, so we will go with a KIT_A2G_TC397_5V_TRB_S and a TC397XE more.
Raktek
Raktek
Mar 16, 2021
03:06 AM
Mar 16, 2021
03:06 AM
Hi Raktek,
ok hopefully you'll find a reasonable solution.
Jens
Jens
