saikiran
10 sign-ins First reply posted First like given
Hi, Iam using aurix TC387 evaluation board. I can able to send CAN Tx message with a particular message ID and sucesfully received at the other end. But I cannot receive messages from the other end. I found only one example for this with loopback mode and could not find any example related to CAN0 reception and message box configuration. In libraries I did not found any function to configure message boxes. Can anyone help me please.
Nambi
5 likes given 100 solutions authored 250 replies posted
Please configure the required message ID via CAN_MESSAGE_ID in the below code snippet and check.
g_mcmcan.canFilter.number = 0;
g_mcmcan.canFilter.elementConfiguration = IfxCan_FilterElementConfiguration_storeInRxBuffer;
g_mcmcan.canFilter.id1 = CAN_MESSAGE_ID;
g_mcmcan.canFilter.rxBufferOffset = IfxCan_RxBufferId_0;
Best Regards.
Nambi
Did you check the discussion in the below thread and test the corresponding example code https://community.infineon.com/t5/AURIX-Development-Studio/CAN0-external-loopback-not-working-in-TC3...
Best Regards.
saikiran
Yeah, I checked the reference. With the code you have suggested TX is working and successfully reached to destination with message ID 0x777 as it is configured as transmit & receive frame type in source node_0. But the actual problem lies in receiving the CAN messages with other message id like 0x111. I am not understanding where I can configure message boxes? I tried to put break point inside RX interrupt service routine. But the breakpoint is not hitting.
Can you please guide me?
Nambi
Best Regards.
saikiran
So, Now we can able to communicate with the external world using CAN0, node0 only.
With this line g_mcmcan.canFilter.id1 = CAN_MESSAGE_ID; we can able to get only the message with that particular CAN_MESSAGE_ID (working as per protocol). But how to configure multiple message objects in order to accept multiple Can messages with different Identifiers? Lets say I want to receive with IDs, 0x01, 0x02, 0x111, 0x777 ....
I found this in Infineon libraries.
// set filter for Rx Buffer 0
 // Initialize the filter structure
 IfxCan_Filter filter;
 filter.number = 0;
 filter.elementConfiguration = IfxCan_FilterElementConfiguration_storeInRxBuffer;
 filter.id1 = 0x00;
 filter.rxBufferOffset = IfxCan_RxBufferId_0;
 IfxCan_Can_setStandardFilter(&canNode[0], &filter);
 // set filter for rxBuffer 1
 filter.number = 1;
 filter.id1 = 0x7ff;
 filter.rxBufferOffset = IfxCan_RxBufferId_1;
In this way we tried but only the first configured one is getting configured and receiving messages from that particular id.
Can you please help me?
