I am trying to configure ATOM5_0 & ATOM5_1 in SOMP counting up mode and be able to reset from the trigger signal of the preceding channels ATOM4_7, however I am unable to generate the PWM for ATOM5_0 & ATOM5_1. I have attached the ATOM register configuration.
Can you please suggest what is wrong with my configuration ?
Aurix
Hello Aiswarya,
I looked into this thread and the use case is different from what I am trying to accomplish.
In my case, I want to use ATOM4_7 as the master and ATOM5_0 and ATOM5_1 as the slave PWM channels. I tried debugging this for several hours but could not figure out what's going on.
When I make ATOM5_0 as master and ATOM5_1, ATOM5_2 as slave channels its works ok, however when ATOM4_7 is made master it does not work, I am not able to figure out what's going on. I am looking for some help to review the my register configuraiton and suggest what is incorrect with configuration.
Can you please help ?
The master-slave using the trigger is applicable only for the sequential channel i.e channel x acts as a master for channel x+1, you can extend longer chain continuously by routing the triggers and also use the trigger from the last channel of ATOM instance x to the first channel of ATOM instance x+1.
Hello Yuva,
Thank you for the feedback. I have configured last channel of ATOM instance x to the first channel of ATOM instance x+1, however for some reason the trigger does not work. Any thoughts ?
Below is snapshot of my configuration. Am I missing something in configuration ?
The trigger configurations appear to be OK. I assume you also start ATOM5_CH0, the edges of the ATOM5_CH0 signal are based on the CM0 and CM1 register values as mentioned in section 28.15.3.3.1 of the UM part 2. Could you check this?
