ATOM in SOMS mode with iLLD?
ntimm
First like received 10 sign-ins 5 sign-ins
i'm using a Aurix TC387 and want to generate and output a custom serial signal. From waht i understand this should be achievable with the ATOM module in SOMS mode but i cant't find any further informations about that in the iLLD documentation.
Is there any example code for that?
Kind regards
TBencher
Level 6
Level 6
25 solutions authored 25 likes received 5 questions asked
since the ATOM belongs to the GTM (BOSCH IP) implementation, you will find all the information on how the GTM works of course inside the User Manual of the Aurix 2G and for more information on that
there is another documentation available directly from BOSCH.
Basically you need to configure the GTM first, before using it. Since the use of GTM is kind of more complex, it is not just be done by two instructions.
If you need help on that, we could provide more information but unfortunately not for free.
Jens
