robs1
Level 4
Level 4
100 sign-ins 50 replies posted First solution authored
Hi, I want to use an ATOM module to create a PWM signal and its inverse PWM negative.
To create the inverse PWM I use the same clock (CMU clock 0) and a different channel, changing the bit SL from 1 to 0. g_atomConfig.signalLevel = Ifx_ActiveState_low;
Is it the smarter way to create the PWM inverse??
The real new question is about the insertion of a time delay. I need a delay/displacement of 100 ns between the PWM signal and its inverse. How I can do it??
My specification is that I have to use the ATOM module and possibly the CMU clock.
Another question is about how can I create a delay between 2 PWM signals?(using atom and cmu clock)
Is there a master-slave mechanism in CMU clocks? How can I handle it?
Thank you in advance.
Yuva
250 replies posted 250 sign-ins 100 solutions authored
GTM DTM block is exactly there for this purpose, please refer to thread in the following link.
https://community.infineon.com/t5/AURIX/Phase-shift-PWM/td-p/398673
Yuva
robs1
Level 4
Level 4
ok thank you.
I need also all channels counting up and down and I setted them but now I don't know how to set the center aligned mode, can you help me?
Yuva
Please refer to section 28.15.3.3.2 in the UM part 2 which has the detailed operation of the up-down mode for ATOM.
