#ARUIX #HEX #RAM #TASKING #flashdriver
Translation_Bot
Why did I use ARUIX to write FLASHDRIVER, modify the LSL link file according to Tasking, and run the target program in RAM. I can see that the target is on the RAM address in the MAP file, but why does the hex file all start with Flash, and the hex file doesn't output the RAM content I want.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/ARUIX-HEX-RAM-TASKING-flashdriver/td-p/680298
Translation_Bot
I solved this problem. I looked for instructions on COPY in the instruction set, and after deleting “COPY,” I was able to find my RAM address in HEX.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/ARUIX-HEX-RAM-TASKING-flashdriver/m-p/681225
Translation_Bot
Hi @银狐,
This is normal. These target programs are linked to an executable file in the form of a data section, but when starting, they are copied by the MCU to the actual place of operation — the RAM area,
BR,
Jeremy
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/ARUIX-HEX-RAM-TASKING-flashdriver/m-p/680408
Translation_Bot
Hi @Jeremy_Z
How can I solve it, modify the software configuration
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/ARUIX-HEX-RAM-TASKING-flashdriver/m-p/680430
Translation_Bot
So how do I output the RAM address I want? I tried it according to the solution on the forum and modified the linked file, and the results were still the same 90fc68262256ee692acf29be25f482c.png a2ac697248bb87d431e6afaf892b725.png
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/ARUIX-HEX-RAM-TASKING-flashdriver/m-p/680421
Translation_Bot
Hi @银狐,
Please check the map file to see what specific address FLS_init () will end up in RAM.
BR,
Jeremy
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/ARUIX-HEX-RAM-TASKING-flashdriver/m-p/681186
Translation_Bot
