Nov 17, 2019
11:11 PM
Nov 17, 2019
11:11 PM
I am currently working on a resolver application, and I refereed to your AppNote AP32270 - Resolver to Digital Conversion Using the DSADC.
There were references to the software and API descriptions in the document. But I couldn't fine the corresponding source code in AppNote or in MyInfineon Collaboration Portal.
Can someone provide the link to download the source code refereed in the AppNote?
12:33 AM
Nov 18, 2019
12:33 AM
More information regarding this topic can be found on https://www.infineon.com/aurix-expert-training. There you can find an example for DSADC also.
You could also give a try to https://www.infineon.com/aurixdevelopmentstudio and you can import examples from https://github.com/Infineon/AURIX_code_examples. All the examples are based on the APIs that you mentioned.
Oct 06, 2021
05:41 AM
Oct 06, 2021
05:41 AM
Hello everyone,
I ran into the same problem. There are references to those files inside the AP32270: Cfg_PosIf_RdcDs.c and IfxDsadc_Rdc.h unfortunately I can not find those codes inside the latest illD, nor Aurix Development Studio nor myicp nor github.
Anyone any ideas where to look next?
Thanks for your help.
