是否可以通过地址直接读写DFLASH
公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
GordonCat
10 sign-ins 5 questions asked 5 sign-ins
您好,
我在其他程序中,看见其使用 *(uint32 *)PSPR_Address, 来读写PSPR地址内的数据,请问,我是否可以采用同样的方式来操作DFLASH的地址内数据。
谢谢!
0 点赞
1 解答
Di_W
Hi GordonCat,
Write DFlash is different with PSPR DSPR, you need to erase sector, enter page mode, write page, please refer to below function in demo code Flash_Programming_1_KIT_TC397_TFT
(https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/Flash_Programming_1_KIT_TC...)
void writeDataFlash()
    uint32 page;                                                /* Variable to cycle over all the pages             */
    /* --------------- ERASE PROCESS --------------- */
    /* Get the current password of the Safety WatchDog module */
    uint16 endInitSafetyPassword = IfxScuWdt_getSafetyWatchdogPassword();
    /* Erase the sector */
    IfxScuWdt_clearSafetyEndinit(endInitSafetyPassword);        /* Disable EndInit protection                       */
    IfxFlash_eraseMultipleSectors(DFLASH_STARTING_ADDRESS, DFLASH_NUM_SECTORS); /* Erase the given sector           */
    IfxScuWdt_setSafetyEndinit(endInitSafetyPassword);          /* Enable EndInit protection                        */
    /* Wait until the sector is erased */
    IfxFlash_waitUnbusy(FLASH_MODULE, DATA_FLASH_0);
    /* --------------- WRITE PROCESS --------------- */
    for(page = 0; page < DFLASH_NUM_PAGE_TO_FLASH; page++)      /* Loop over all the pages                          */
        uint32 pageAddr = DFLASH_STARTING_ADDRESS + (page * DFLASH_PAGE_LENGTH); /* Get the address of the page     */
        /* Enter in page mode */
        IfxFlash_enterPageMode(pageAddr);
        /* Wait until page mode is entered */
        /* Load data to be written in the page */
        IfxFlash_loadPage2X32(pageAddr, DATA_TO_WRITE, DATA_TO_WRITE); /* Load two words of 32 bits each            */
        /* Write the loaded page */
        IfxFlash_writePage(pageAddr);                           /* Write the page                                   */
        /* Wait until the data is written in the Data Flash memory */
  dw
在原帖中查看解决方案
0 点赞
2 回复数
Di_W
Hi GordonCat,
  dw
0 点赞
GordonCat
OK, I see, thank u for replying.
0 点赞
