基于SOTA功能,重新配置PFLASH空间大小
公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
Ralphance
25 sign-ins 5 likes given First like received
对于执行SOTA功能后,我是否可以不按照手册说明,分配PFLASH,是否可以自己规划"A" "B"分区的PFLASH的空间大小?
0 点赞
4 回复数
SIX_66
Level 6
Level 6
First comment on blog 500 replies posted 250 replies posted
学习学习
0 点赞
evenchen
Level 4
Level 4
Distributor - Intron(GC)
10 sign-ins First reply posted First like given
我理解不可以,AB Bank的大小是固定的,参考英飞凌的usermanual
0 点赞
Sniff1992
10 comments on blog 5 comments on blog First comment on blog
>>不可以,以PFlash Blank为最小单位。例如:将多个PFlash Bank设置为A组,其它的几个PFlash Bank为B组,并且要保证大小一致。需要注意:1.TC3Xxx系列只有一个1M的PFlash Bank,其它PFlash Bank均为3M,如果1M的PFlash Bank使用的话,会导致部分内存的浪费;2.需要关掉Fast Path访问本地的PFlash,地址SWAP后,无法保证所有的PFlash均为local。 原文: In this chapter, the group of banks active in the standard address map is referred to as ‘A’ and the group of banks active in the alternate address map is referred to as ‘B’.
0 点赞
marchcui
25 replies posted 10 replies posted 5 replies posted
不可以
0 点赞
