Hello everybody,
I've received a TX375 lite kit form my University onto which I should port an already written library . Such library is completely written in C++, hence I would like to be able to write the rest of the code in C++.
I'm having some trouble making AURIX Development Studio recognize and compile C++ code.
Up until now I've tried different settings and things found on the internet and/or on some old manuals (I'm running v1.5.4, but the most updated manual I could find is v.1.4 something), but I couldn't make it work. I've tried using an external compiler, but I cannot access a Tricore compiler, I've tried following this guide, but it does not work, nor does any other option I set.
Is there anyway to compile C++ code with AURIX Development Studio or do I have to re-write all the code to C?
Thank you very much,
Enrico
Hi Enrico,
I'm using Aurix Development Studio V1.5.4 and the pre-compiled DMA_ADC_Transfer_1_KIT_TC375_LK example program and in that I've manually added function (_Z12__call_ctorsv();) as mentioned in the thread https://community.infineon.com/t5/AURIX/Use-C-to-development-TCxxx-like-tc275/m-p/318464 in a C file in the project and I see the Compilation is successful.
Could you please check if all the options required for C++ build are enabled. You may check those in the below windows:
1.
2.
Are above options configured in your project ?
Hi Enrico,
1.
2.
Hi Prudhvi,
Thank you very much for answering. Yes, all the options were correctly set, and actually my error was on extern "C" syntax, so nothing related to AURIX.
I don't know whether asking another question is good practice for this forum or not, but now that I'm able compile and link C++ code, I've written a simple function that assigns an int value to a variable, but when I try to run it and set a break point to the variable to check whether it is working fine, I get the following error: "Default:Cannot read variable, no storage assigned." What am I doing wrong? I attach the code below.
// libraries/service/test/test.hpp
#pragma once
#ifdef __cplusplus
#define EXTERNC extern "C"
#else
#define EXTERNC
#endif
EXTERNC int value();
// libraries/service/test/test.cpp
#include<test/test.hpp>
int value () {
int a=3;
return a;
// Cpu0_Main.c
#include "Ifx_Types.h"
#include "IfxCpu.h"
#include "IfxScuWdt.h"
#include <test/test.hpp>
IFX_ALIGN(4) IfxCpu_syncEvent g_cpuSyncEvent = 0;
void core0_main(void)
IfxCpu_enableInterrupts();
/* !!WATCHDOG0 AND SAFETY WATCHDOG ARE DISABLED HERE!!
* Enable the watchdogs and service them periodically if it is required
IfxScuWdt_disableCpuWatchdog(IfxScuWdt_getCpuWatchdogPassword());
IfxScuWdt_disableSafetyWatchdog(IfxScuWdt_getSafetyWatchdogPassword());
/* Wait for CPU sync event */
IfxCpu_emitEvent(&g_cpuSyncEvent);
IfxCpu_waitEvent(&g_cpuSyncEvent, 1);
int v=0;
// printf("1v: %d\n", v);
v=value();
// printf("2v: %d\n", v);
v=6;
while(1)
EDIT: apparently yesterday evening I was not really awake... The only problem with the above code is the missing #include<stdio.h> to let the program know where to get printf()...
Good to know that you're issue is solved !!
Thank you for you help. This worked for me!
