I installed AURIX-v1.6.0 Development Studio and selected one of the provided projects - Multicore_1_KIT_TC397_TFT which matches the target board that I have plugged into my USB port. I had previously run the DAS_V7_3_7_SETUP.exe and there is a C:/Program Files/DAS64 folder of tools on my system.
The project built without any issues. I then setup a debug configuration and it identifies a Generic Infineon AURIX Board with the TC39xB (I also tried just TC39x). The connection states Universal Debug Access Server with a Host Port / localhost 23.
When I click on Debug, it says Error creating session with the following details:
The debug instrument IO could not be initialized.
The GDI debug instrument provided the following error message.
Could not open Access HW
In the Console window it has:
Using Debug Target Configuration:
Target: Generic Infineon AURIX Board
Selected CPU type: tc39xb
Register file: D:/Infineon/AURIX-Studio-1.6.0/plugins/com.tasking.ctc.debug.win32.x86_64_1.12.14.0/ctc/include/sfr/regtc39xb.xml
Communication: Universal Debug Access Server
Debug Instrument Module: gdi2mcdtc
Using Flash Configuration:
Monitor : D:\Infineon\AURIX-Studio-1.6.0\plugins\com.tasking.ctc.debug.win32.x86_64_1.12.14.0\ctc\etc\ftc39xb.sre
Workspace address : 0x70000000
Number of devices : 10
Sector buffer size : 8192
Device 0:
Address : 0xA0000000,0x80000000
Vendor : Infineon
Chip : TC3_17624k
Subname : Program Flash 0
Width : 32
Number of chips : 1
Unused address lines : 0
Device 1:
Address : 0xA0300000,0x80300000
Vendor : Infineon
Chip : TC3_17624k
Subname : Program Flash 1
Width : 32
Number of chips : 1
Device 2:
Address : 0xA0600000,0x80600000
Vendor : Infineon
Chip : TC3_17624k
Subname : Program Flash 2
Width : 32
Number of chips : 1
Device 3:
Address : 0xA0900000,0x80900000
Vendor : Infineon
Chip : TC3_17624k
Subname : Program Flash 3
Width : 32
Number of chips : 1
Device 4:
Address : 0xA0C00000,0x80C00000
Vendor : Infineon
Chip : TC3_17624k
Subname : Program Flash 4
Width : 32
Number of chips : 1
Device 5:
Address : 0xA0F00000,0x80F00000
Vendor : Infineon
Chip : TC3_17624k
Subname : Program Flash 5
Width : 32
Number of chips : 1
Device 6:
Address : 0xAF000000
Vendor : Infineon
Chip : TC3_17624k
Subname : Data Flash 0
Width : 32
Number of chips : 1
Device 7:
Address : 0xAF400000
Vendor : Infineon
Chip : TC3_17624k
Subname : Data Flash UCB
Width : 32
Number of chips : 1
Device 8:
Address : 0xAF800000
Vendor : Infineon
Chip : TC3_17624k
Subname : Data Flash CFS
Width : 32
Number of chips : 1
Device 9:
Address : 0xAFC00000
Vendor : Infineon
Chip : TC3_17624k
Subname : Data Flash 1
Width : 32
Number of chips : 1
Configuration: TC39xB
Starting Debugger...
Please Advice, thank you.
Could you share a picture of your setup?
Could you try the following steps and let us know your observation?
i) Connect your TC397_TFT kit using USB to PC.
ii) In Aurix Development studio, build the project blinky_led_1_kit_tc397_tft.
iiI) Choose Debug-->Debug Active Project menu from Aurix Development studio
Best Regards.
