Aug 17, 2022
05:04 AM
Aug 17, 2022
05:04 AM
Hej,
is it possible to configure or select which ILLDs (PSI5 or QSPI for example) shall be used in a project or can i just delete the folder in Library?
BR
Forvia
- illd
10:21 PM
Aug 21, 2022
10:21 PM
In the earlier version of ADS, there is an option to select a reduced set of iLLD drivers (pre-defined) but in the current release all the drivers of the devices are imported. You need to remove the unused drivers.
10:21 PM
Aug 21, 2022
10:21 PM
