Mar 05, 2021
12:07 AM
Mar 05, 2021
12:07 AM
Hello all
I have got TC397 eval board and
i can able to run the examples which are imported from aurix repo, But the problem is with when i have created a project using "new aurix project" option in the file menu and selecting TC397 Board in the processor option.
I can dump the generated binary to the board. But the file is not giving any results. i have used debugger the program is going to while(1) condition Cpu0_main.cin file.
please suggest me how to create a project so that i can run on TC397 eval board.
- aurix tc399
11:12 PM
Mar 07, 2021
11:12 PM
When you create a "New AURIX Project" on AURIX Development Studio, it creates an empty project that does nothing. Therefore if the debugger enters the while(1) foverer, it is correct.
If you want to use any peripheral of the AURIX TC397, please import an example following: File >> Import... >> Infineon >> "AURIX Development Studio Project", select "Infineon Code Examples Repository" and select the code example to be imported.
teoBits
teoBits
