I`m getting this error when I build the project.
and this is the location where error happen:
I couldn`t understand why it is saying "two architectures defined with the name TC". I didn`t defined the architecture somewhere else or didn`t changed this lsl file. It is default file when I create a project.
By the way, I added lsl file here. Before this it was giving lots of unresolved external error and this is solved that problem.
how can I solve this problem?
Hello! Please note that the Linker Script Language (LSL) file is not a library. As a result you should not add this file in the library section of ADS. An ADS project includes the LSL file named
Lcf_Tasking_Tricore_Tc.lsl
by default. If you are familiar with the LSL language, you can start to modify the given LSL file. If you want to fully replace this by another LSL file, you need to adapt the entry in the command line pattern in the TASKING Linker section. This includes the entry:
--lsl-file=../Lcf_Tasking_Tricore_Tc.lsl
which can be adapted.
The error message you include in your original post shows up, because two LSL files are included and both do define the TC architecture.
Ulrich Kloidt
TASKING tools support
Could you let us know the example project being tested/built here?
Could you let us know the ADS version used at your end?
Best Regards.
ADS version is 1.8.0
I created a new project and try to compile with my own files.
Is there any idea to solve this problem? I tried to use "include guard" to solve but it didn`t worked.
I added something similar to this in the lsl file:
#ifndef xxxxx
#define xxxxx
#endif
Could you please try selecting "New AURIX Project" instead of "Project" when you create own project. Once it is created, you can add your own files. By default, certain settings related to Build process and Linker and startup files are created automatically which you can adapt to your project needs. If you don't want certain files, you may exclude those from build or remove from project.
Prudhvi.
hi,
Thank you for the answer. I did what you said, project created as a Aurix Project and I add new files. I don`t know why new files effected the compilation. I think this error coming out because I added lsl file in libraries section(screenshot is in first post). I did this to solve unresolved external errors. It was giving unresolved external error for all .o files.
Ulrich Kloidt
