I'm using the Aurix Development Studio 1.5.4.
I created a library project like mentioned in the ADS help, but it seems that the tasking binary is missing.
Error message is:
/aurix-studio-1.5.4/plugins/com.infineon.aurix.tools_1.5.4/build_system/tools/make/sh: artc: not found
make: *** [makefile:155: 377_Illd.a] Error 127
Something to change on my side?
AURIX
It looks as if older ADS versions did not include the archiver executable. But is has been added in ADS v1.5.2 and should also be part of ADS v1.5.4 as far as I know. I reported this issue internally.
A mitigation is to use the artc.exe included in ADS v1.5.2. I attached the executable. Please unzip it and copy it into the folder:
AURIX-Studio-1.5.4\plugins\com.infineon.aurix.tools_1.5.4\build_system\tools\Compilers\Tasking_1.1r8\ctc\bin
of your ADS v1.5.4 installation. Afterwards you can create library projects again.
Ulrich Kloidt
TASKING tools support
Dear ,
The archiver artc is not included in the Infineon Aurix Development studio as ADS is not designed to be a full featured TASKING toolset.
I assume the library creation topic in the ADS help is a leftover from the original TASKING Compiler documentation.
Please also note that the TASKING components (compile, assembler, linker, etc) are not designed to be run from command line outside ADS.
With kind regards
TASKING Support
Ulrich Kloidt
Thank you,
I just reinstalled ADS 1.5.4 with the downloadable installer .exe. to recheck, but the archiver artc.exe was not installed.
With the executable provided by you from 1.5.2, the lib binary was build under ADS 1.5.4.
