I am trying to get a working combination of the wl tool and the brcmfmac43455 "mfg" firmware for fcc compliance testing. I have a wl tool and brcmfmac43455-sdio.bin from raspberrypi.org, If have also downloaded every instance of wl, wlfmac, wlarm_le and wlarm64 version of wl I can find on this forum. All roads seem to end in the often mentioned "wl driver adapter not found" , "error -23" or warnings about the "libnl" version.
I am willing to use any OS, raspian, ubuntu, 32 or 64bit.
Can you please send me or point me towards a working combination of files?
Thanks!
Wireless
Hi @scottc385, Please find the wl tool attached. Could you please try the same and let us know if the wl tool command works? and regarding the MFG tool i have created a case and you should have got a notification to your email regarding the same.
