Dear Sir,
When i use wl command and it show error message,could you have any suggestion.
uname -a
Linux imx6ulevk 5.4.47-lts-lf-5.4.y+g88b2efd7d692 #1 SMP PREEMPT Fri Dec 3 13:26:06 UTC 2021 armv7l armv7l armv7l GNU/Linux
platforme:imx6ulevk
error message:
error while loading shared libraries: libnl-nf-3.so.200: cannot open shared object file: No such file or directory
B.R.
Bill
Hi @Bill_123 ,
Since you are using fmac drivers, the wl executable requires libnl libraries to be installed. Two ways you can fix it.
1. You can download the libnl source code online,compile it and install it on your host.
Or
2. You can use a statically compiled wl tool available here in "wl32s.zip" package. : https://community.infineon.com/t5/AIROC-Wi-Fi-and-Wi-Fi-Bluetooth/Wireless-tool-wl-for-armhf-archite...
Dear raks_99,
Thanks for your information.
B.R.
Bill
