- Email to a Friend
Dear Sir,
When I do iperf test, the error is shown.
After the error message is shown, we will not use "wl" command.
What is mean for " brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110"?
The issue is not easy duplication.
Do you have any suggestions?
/ # wlverver ver
[ 581.340899] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
wl: wl driver adapter not found
/ # Jan 1 00:09:41 buildroot user.err kernel: [ 581.340899] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
/ # dmesg | grep brcm
[ 25.393879] brcmfmac: F1 signature read @0x18000000=0x172d4355
[ 25.400201] brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac54591-sdio for chip BCM4355/13
[ 25.412474] brcmfmac: brcmf_fw_request_firmware: no board-specific nvram available (ret=-2), device will use ./cypress/cyfmac54591-sdio.txt
[ 25.638103] brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac54591-sdio for chip BCM4355/13
[ 25.653364] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4355/13 wl0: Jan 21 2022 04:45:03 version 13.35.266 (1c22d4b CY WLTEST) FWID 01-f09288b2
[ 25.671658] brcmfmac: brcmf_pktfilter_add_remove: add packet filter failed, ret=-23
[ 55.393850] brcmfmac: brcmf_cfg80211_vndr_cmds_dcmd_handler: oversize return buffer 130048
[ 324.316897] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
/ # / # dmesg | grep brcmfmcac
/ # lsmod
Module Size Used by Tainted: G
brcmfmac 323584 0
brcmutil 20480 1 brcmfmac
cfg80211 393216 1 brcmfmac
compat 16384 2 brcmfmac,cfg80211
rfkill 20480 1 cfg80211
/ # top
Mem: 59912K used, 40084K free, 616K shrd, 11528K buff, 29548K cached
CPU: 0% usr 4% sys 0% nic 95% idle 0% io 0% irq 0% sirq
Load average: 0.00 0.00 0.00 1/59 265
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
265 175 root R 2796 3% 5% top
150 1 root S 76116 76% 0% /usr/bin/util_svc -b
126 1 root S 3196 3% 0% /sbin/mdev -df
175 1 root S 2932 3% 0% -/bin/sh
1 0 root S 2796 3% 0% init
158 1 root S 2796 3% 0% klogd
160 1 root S 2796 3% 0% syslogd -O /dev/ttyS1
165 1 root S 2796 3% 0% /usr/sbin/telnetd -F
251 1 root S 2796 3% 0% udhcpc -i wlan0
148 1 root S 2300 2% 0% /usr/bin/ipcbind -b
153 1 root S 2252 2% 0% /usr/bin/camctrlserver
197 2 root IW< 0 0% 0% [kworker/u9:1-br]
30 2 root IW 0 0% 0% [kworker/0:1-mm_]
106 2 root IW< 0 0% 0% [kworker/0:1H-kb]
9 2 root SW 0 0% 0% [ksoftirqd/0]
27 2 root IW< 0 0% 0% [kworker/3:0H-kb]
56 2 root IW< 0 0% 0% [kworker/u9:0-br]
10 2 root RW 0 0% 0% [rcu_preempt]
31 2 root IW 0 0% 0% [kworker/3:1-mm_]
105 2 root IW 0 0% 0% [kworker/0:2-eve]Mem: 59952K used, 40044K free, 616K shrd, 11528K buff, 29548K cached
CPU: 0% usr 0% sys 0% nic 100% idle 0% io 0% irq 0% sirq
265 175 root R 2932 3% 0% top
30 2 root IW 0 0% 0% [kworker/0:1-eve]
10 2 root IW 0 0% 0% [rcu_preempt]
CPU: 0% usr 0% sys 0% nic 99% idle 0% io 0% irq 0% sirq
/ # ps
PID USER COMMAND
1 root init
2 root [kthreadd]
3 root [rcu_gp]
4 root [rcu_par_gp]
7 root [kworker/u8:0-ev]
8 root [mm_percpu_wq]
9 root [ksoftirqd/0]
10 root [rcu_preempt]
11 root [migration/0]
12 root [cpuhp/0]
13 root [cpuhp/1]
14 root [migration/1]
15 root [ksoftirqd/1]
16 root [kworker/1:0]
17 root [kworker/1:0H]
18 root [cpuhp/2]
19 root [migration/2]
20 root [ksoftirqd/2]
21 root [kworker/2:0]
22 root [kworker/2:0H]
23 root [cpuhp/3]
24 root [migration/3]
25 root [ksoftirqd/3]
27 root [kworker/3:0H-kb]
28 root [kdevtmpfs]
29 root [rcu_tasks_kthre]
30 root [kworker/0:1-eve]
31 root [kworker/3:1-mm_]
32 root [oom_reaper]
33 root [writeback]
34 root [kcompactd0]
41 root [cryptd]
54 root [kblockd]
55 root [rpciod]
56 root [kworker/u9:0-br]
57 root [xprtiod]
103 root [kswapd0]
104 root [nfsiod]
105 root [kworker/0:2-eve]
106 root [kworker/0:1H-kb]
107 root [kworker/0:2H]
108 root [kworker/3:1H]
126 root /sbin/mdev -df
148 root /usr/bin/ipcbind -b
150 root /usr/bin/util_svc -b
153 root /usr/bin/camctrlserver
158 root klogd
160 root syslogd -O /dev/ttyS1
165 root /usr/sbin/telnetd -F
166 root [kworker/u8:1]
175 root -/bin/sh
188 root [cfg80211]
189 root [brcmf_wq/mmc0:0]
190 root [brcmf_wdog/mmc0]
197 root [kworker/u9:1-br]
203 root [kworker/3:2]
251 root udhcpc -i wlan0
266 root ps
- Email to a Friend
Hi @Bill_123, thank you for the update, can we close this now as further communication would happen on the Mycase?
Vivek.
- Email to a Friend
Hi @Bill_123 , Could you please let us know which host, kernel version, and driver version is used for testing?
- Email to a Friend
Dear Vivek,
chip:CYW54591
fmac-v5.10.9-2022_0331
host:AMBA CV25
Linux with kernel ver. 5.4
B.R.
Bill.
- Email to a Friend
Hi Bill, for further debugging i might have to share some test firmware and patches.
Could you please raise a Mycase request? I can share the same in Mycase.
Vivek.
- Email to a Friend
Dear Vivek,
Because the issue is not easy duplication, we will find a method to easy duplicate the issue and then to create a new mycase.
When we create a new mycase, we will share the information to you.
We appreciate your help very much.
B.R.
Bill.
- Email to a Friend
Vivek.
