harelTur
25 sign-ins 10 replies posted 10 questions asked
Hi
I use mfg test with platform of Murata Type1LD.
I add the platform with patch file and run an example of scan.
I try to run example of mfg test due to document of mgf test Type1LD ApplicationNote
RF Test.
I get error from WICED "mfg_test application does not support MurataType1LD platform:
Do you can help me? please...
raks_99
First question asked 250 replies posted 250 sign-ins
Have you added the platforms file for the Type1LD in wiced?
If not then you can contact Murata to get the files.
raks_99
