I am working on a POC for wifi connectivity with muRata 1DX. And purchased the "Nebula rev 2.0 IOT DEVELOPMENT KIT". And needed to flash a code for testing purpose. However, I need the default source code of the f/w that’s running on the Nebula rev 2.0 IOT DEVELOPMENT KIT. And also what all flash-tools are supported for this. Can you please guide in this?
If you mean firmware for WLAN chip, we won't provide that but if you're asking about default application code that runs on the chip when it is shipped, you'll have to get in touch with Future Electronics since they are the provider of this board.
Regarding flash tools, if you are using wiced, then OpenOCD is supported for flashing the code.
Phanindra
Phanindra
