Is there a way to let the wifi chip automatically negociate the country with AP ?
The need is to be to enable channels 13 / 14 by default then let the country be set automatically
This is to ease device configuration
This exists on some other solution, but not found in WHD API.
Community Information
I think the feature that you want for your use case is - Dynamic SKU Method. You can check this out in the Wi-Fi CLM Regulatory Manual (section 6.1). The link for the same is -
https://www.cypress.com/documentation/application-notes/an225347-cypress-wi-fi-clm-regulatory-manual
You can have a custom autocountry implementation by picking up country code from scan results.
Aditi
this is more clear now
