Which radio chips currently support WPA3?
What is the plan for those chips that don't currently support WPA3?
What methods are available to update certified modules that were produced before WPA3 support was added?
“WPA3 is a mandatory certification for Wi-Fi CERTIFIED™ devices.” per WiFi alliance https://www.wi-fi.org/discover-wi-fi/security
Greg
Various Infineon chipsets support WPA3. Chipsets CYW4373, 43439, 4373E, 43907, 43438,4343W support WPA3. Also, chipsets with less memory like CYW43012 support WPA3 with external supplicant.
Aditi
Aditi
