GrCa_1363456
Level 6
Level 6
50 likes received Beta tester First comment on KBA
Designing with a Hosted radio module such as CYW43012, (in a Murata 1LV form factor), requires loading a WiFi stack onto a separate processor. How much memory should be allocated for the WiFi stack? Is there a minimum size and typical size for each radio module?
Greg
Rakesh_BG
50 solutions authored 100 replies posted 100 sign-ins
Hi @GrCa_1363456 ,
For basic working radio, approximate memory size required is 470 KB which includes the size of binary file, clm_blob file and nvram component.
Actual size varies on network stack, RTOS and other requirements you choose.
Rakesh_BG
Hi @GrCa_1363456 ,
