- Email to a Friend
Hi
I use Cypress 4343 - my component is Laired sterling..
I see problem with scan results,
In my environment the RSSI value that print in the log is "OFF".
I check inside the code and I found that this "OFF" arrived from WICED_SCAN_RESULT_FLAG_RSSI_OFF_CHANNEL
but I don't understand what the problem? who set the flags to be WICED_SCAN_RESULT_FLAG_RSSI_OFF_CHANNEL
Can you help me
Harel
- Email to a Friend
Kindly refer to this link that explains off-channel scanning https://www.wi-fi.org/knowledge-center/faq/what-is-off-channel-scanning-for-wi-fi-client-devices
- Email to a Friend
OK,
So who is set this settings??
How I can change it?
Harel
- Email to a Friend
Hi @harelTur ,
WICED_SCAN_RESULT_FLAG_RSSI_OFF_CHANNEL gets set based on the scan results.
OFF channel is basically gets set when the AP's probe response is in different channel than your probe requested channel.
Rakesh B G
