hi
We design products with CYW43438,it can run normally,but the SR_VLX of CYW43438 output voltage is between 0.85V to 1.4V.Why is that?We confirm that the input voltage is normal!Does the chip enter the low power mode? If so, please provide the register manual, thank you!
As per the internal team, the switching regulator is using a switch to turn on and off frequently to realize the voltage regulation. If this is happening and is being observed, then this is normal.
Aditi
I'm not sure if the register manual can be available publicly but I'll check with the hardware team and will revert back.
Aditi
Hi Aditi,
How's it going ?Is there a conclusion?
Aditi
Thank you for your reply!I also confirm that The internal output voltage is regulated by the chip.Now, I want to know if the internal output with 2.2UH inductor and 4.7uF capacitor can be adjusted by the chip to provide a stable voltage. According to my understanding, the power supply should be adjusted by parameters.
As per the team, they want to know what's the concern on your side and what do you want to adjust? The inductor and capacitor are critical components that had been suggested by the PMU team thus they don’t suggest the customer do any adjustment on the value or spec.
Aditi
Thanks,The specification describes that the core voltage should work above 1.4V, That's why I'm a little worried.It's not recommended to adjust, so I have no confused,Thanks again!
