- Email to a Friend
Hi all,
Noticed the "Test Environment" in the https://community.infineon.com/gfawx74859/attachments/gfawx74859/WiFiBluetoothLinux/1911/2/cypress-f....
I'm curious about the criteria of kernel revision selection. Could you help me to understand it?
I would like to build a exactly the same test environment. Could you please share following (or more) detailed info?
- The hardware of ARM (MCIMX6SX-SDB) and X86
- The model
- The software of ARM (MCIMX6SX-SDB) and X86
- The OS and it's revision
- The FW/image or SDK for i.MX6?
"Test Environment
* ARM (MCIMX6SX-SDB)
* Linux v4.14.78 (NXP imx_4.14.78_1.0.0_ga)
* backports
* x86
* Linux v4.12
* backports
David Zou
- Email to a Friend
You can get in touch with NXP for more details on the board https://www.nxp.com/part/MCIMX6SX-SDB#/
The image used is "NXP imx_4.14.78_1.0.0_ga" you could also check with NXP for the same.
- Email to a Friend
- Email to a Friend
Thanks for the info of NXP, @Vivek_gunapati.
How about the x86?
- Email to a Friend
Hi @DaZo_4818121 most of the testing is done on the GB-BXi7-5775
- Email to a Friend
What's the OS and version? Ubuntu or others? Please share more info.
- Email to a Friend
Hi @DaZo_4818121 From the README file of version v5.10.9-2022_0511 below is the test environment
Test Environment
* backports
* x86
* Linux v4.12
* backports
in x86 the tested linux version is v4.12. ideally the distribution should not matter. but the kernel version does.
Vivek.
- Email to a Friend
