I am trying to compile STM32 connectivity expansion pack examples for STM32H7. I followed same steps mentioned in user guide.
https://github.com/Infineon/stm32-connectivity
I am getting following error:
../../Middlewares/Third_Party/Infineon_Wireless_Connectivity/wifi-host-driver/resources/nvram/TARGET_CY8CKIT_062S2_43012/wifi_nvram_image.h:22:10: fatal error: ../generated_mac_address.txt: No such file or directory
Where can I find "generated_mac_address.txt" file? I haven't modified code and its out of the box example.
Thank you.
You can find this file in this location -
C:\Users\<USER>\STM32Cube\Repository\Packs\Infineon\Connectivity-STM32\1.1.0\Middlewares\Third_Party\wifi-host-driver
Copy this file and paste this into the project folder at the location -
<Project_location>\<application>\CM7\Core\Inc
Let me know if this helps.
Aditi
Aditi
Hi Aditi,
Thank you for solution. It worked fine. I got some other errors in wifi_task.c file - function app_init() ->undefined reference to `BSP_LED_Init', "SP_COM_Init', 'BSP_LED_On".. basically all BSP related function calls. I commented them out and I could compile code. Thanks for help.
Vishal
Thanks for the update. If you don't want to comment these functions, you need to add the relevant platform .h (header files) and .c(source files) in the same location as above mentioned.
The .h files will go in this location -
<project_folder>\<application>\CM7\Core\Inc
The .c file will go in this location -
<project_folder>\<application>\CM7\Core\Src
Aditi
