We are working on integrating Wi-Fi module Murata Type1 MW LBEE5HY1MW(Cypress CYW43455) with STM32F4 based micro-controller using SDIO interface.
We are looking for SDIO Driver and Murata Wi-Fi driver for STM32F4 based micro-controller (Running FreeRTOS).
anyone here having any reference for the same? or
anyone know where we can get them to integrate it in our system?
It would be also great help if there are any compatible software that we can port on STM32F4 based micro-controller.
Dipak Sharma
Hello Dipak
We did have the 43455 EVB pre-wiced 6.4 which was based on the STM32H7. Maybe you could use this as a starting point. But I strongly recommend that you contact your local Infineon sales/marketing team and get this request evaluated as we don't have support for 43455 on WICED in the latest versions.
The driver that you could use to port is available here https://github.com/cypresssemiconductorco/wifi-host-driver
But, where are you planning to port this to?
We support 43455 on linux based platforms.
HI Murali,
We are planning to port the driver on FreeRTOS.
Is there something we have to consider?
Dipak Sharma
@Dipak FreeRTOS is fine. But what I meant was what is the environment that you plan to use this on. Is it WICED or some other IDE? If so, I suggest that you contact your local infineon sales/marketing team and get this request evaluated as we don't have support for 43455 on WICED out of the box in the latest versions.
HI Murali,
We have a STM32F4 based host MCU running FreeRTOS and we are using IDE provided by STM which is STM32 CubeIDE for development purpose.
We are looking for the STM32 CubeIDE solution. If WICED sdk solution is available we can port on STM32 CubeIDE.
Dipak Sharma
Hello Dipak
HI Murali,
Thanks for the information. It will surely help us.
Dipak Sharma
