I try to get started with the 43012 on the CY8CKIT-062S2-43012.
Connecting with the Wi-Fi works but as soon as I add some function like cy_socket_gethostbyname or task I get the following terminal output:
What is here the problem, what causes the problem and how can I solve this.
Phil
- whd
the failure has been found.
The FreeRTOSConfig.h file that is downloaded with the library manager or make getlibs needs to be updated as follows:
#define configNUM_THREAD_LOCAL_STORAGE_POINTERS 16
#define configMAX_CO_ROUTINE_PRIORITIES 2
#define configTIMER_TASK_PRIORITY 2
After that it works properly.
Phil
Phil
